need part# for opti seal on timing cover
Old Feb 24, 2004 | 11:52 AM
Fbody1's Avatar
mine is leaking , was going to get the timing cover set ( napa said that one was in it ) but it does not have one in it, thanks
Old Feb 24, 2004 | 12:14 PM
Will84's Avatar
It's just a little blue o-ring. Go to any GM parts department and they will have it. It's only a dollar and some change.
Old Feb 24, 2004 | 01:02 PM
Brandon 95 Z28's Avatar
I think he means the larger seal that seats in the tming cover, not the O-ring seals on the shaft. I got mine out of the felpro timing cover gasket set, about 14 dollars at autozone. I couldnt find one seperately.
Brandon
Old Feb 24, 2004 | 01:03 PM
Not the o-ring, but the cover seal:
1995-1997 front cover opti seal GM p/n 12552428
Old Feb 24, 2004 | 04:22 PM
Fbody1's Avatar
it's the one that is attached to the timing cover, should I change the one on the shaft also? thanks
Old Feb 24, 2004 | 05:50 PM
Mtrhds94Z's Avatar
Looks like he has a 94 so it's:
Timing Cover Opti Seal GM 10128317 [95^ is 12552428]
Opti Drive Shaft Orings 10474278
Yes replace the Orings too they are cheap..
Old Feb 24, 2004 | 07:29 PM
Thanks Charlie. Guess I looked at one of the other sigs.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
