Need part numbers ASAP
Old Mar 24, 2004 | 04:33 PM
madhatter's Avatar
I need the part numbers for every part I will need to change out my dead opti. 94 non vented.
Thanks in advance.
Old Mar 24, 2004 | 04:40 PM
Two water pump gaskets..Fel Pro_35072 or GM 10128343
1993-1994 optispark (non-vented) 10457702
Old Mar 24, 2004 | 04:57 PM
madhatter's Avatar
That's it? Every that I will need?
Old Mar 24, 2004 | 06:41 PM
madhatter's Avatar
Is that everything that I will need? No gasket for the opti or anything else? Also, who has an install page for it?
Any help at all ASAP would be highly appreciated.
Old Mar 24, 2004 | 11:02 PM
1993-1994 front cover opti seal 10128317 if you need one.
Here is a guide, but it is for a 95+, so your opti drive will look a little different.
Just be sure to note the "keyway" on your opti drive and re-install it properly.
Old Mar 27, 2004 | 02:15 PM
madhatter's Avatar
Thanks man! You rock!
Car runs smoother than ever. Track day is tomorrow, we shall see how it goes.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
