Need Opinions on TPIS LT1 405HP Engine Package
Old Feb 10, 2003 | 09:47 PM
  #31
sleeperZ96BT's Avatar
its a tad pricey but not overly outrageous. you do get a lot, short of heads and they are nice parts. hell, if you run FLP's and a stainless system other than the loudmouth you are approaching $2g's right there. pricey it sure is and there are probably much cheaper ways to do it, but TPIS is a very reputable company, so you know its a legit package. your money, your call.
brian
Old Feb 10, 2003 | 10:15 PM
  #32
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
$4600 better get me more than out of his mirror.
Holy christ!
****, give me $4600 and i'll build you a 500hp motor
Lloyds heads- $500
eagle forged rotating assembly- $2000
Valve Train- $850
gaskets, timing chain, oil, extras- $ $1000
machine work- $500
and i've been generious.
Good lord.
I've forgotten how expenive this crap is.
please tell me this thing includes more than bottom end, heads, cam...
Old Feb 10, 2003 | 10:19 PM
  #33
Grease's Avatar
The kit includes:
Camshaft - Ported LT1 heads - 52mm Throttle body - Spark plugs wires - spark plugs - fuel pressure regulator - headers with y-pipe - Gale Banks cat-back - air filter - reprogrammed PCM - MSD 6AL - head gaskets etc.
Oh yeah, and its emmisions legal in all 50 states
Old Feb 10, 2003 | 10:23 PM
  #34
treyZ28's Avatar
Originally posted by Grease
The kit includes:
good price then
what bottom end?
Old Feb 10, 2003 | 10:26 PM
  #35
Grease's Avatar
Originally posted by treyZ28
good price then
what bottom end?
Oh, no. No bottom end there. Basically its a head/cam/exhaust package.
Old Feb 10, 2003 | 10:37 PM
  #36
treyZ28's Avatar
holy **** me in the *** without lube batman!
custom ground Camshaft $400
Ported LT1 heads - varries
52mm Throttle body $300
Spark plugs wires spark plugs ($100)
fuel pressure regulator ($100)
- headers with y-pipe $700
Gale Banks cat-back $300
- air filter
- reprogrammed PCM $150
- MSD 6AL $300
- head gaskets etc. $500
I'm at 2600
I'm lost
maybe they can go sucker a vette guy into to buying it
I'm not paying $2000 for their port job when there is phil and lloyd for $1500 and $500 respectivly.
maybe you forgot rockers and springs?
either way- figure another $100 on top of a custom ground cam for an LT4 HC kit or something??
LT4 Hc guys are making 400hp on stock bottom ends arne't they?
and drop the 52mm tb and pressure regulator. you dont need either.
Old Feb 10, 2003 | 11:06 PM
  #37
Grease's Avatar
I never said I agreed with their pricing
Their heads cost 1500$ fully assembled with manley 2.00/1.56 valves
TPIS ZZ9 camshaft - 375$
TPIS headers - 750$
Gale Banks catback - 375$
TPIS 52mm TB - 280$
TPIS AFPR - 120$
Airfilter - 50$
Plug wires - 87$
MSD 6AL - 200$ (everywhere else its 150$ like at Summit)
TPIS head gaskets - 40$ each (in actual fact impala head gaskets)
Can't remember how much their programming was but it was over 500$ if I'm not mistaken
Thats 4417$ right there.
The only gaskets included in the kit are the head gaskets and maybe TB gaskets.
Looks pricey doesn't it? But when you look closely at it thats what you pay for parts you'd buy individually. Most sets of ported LT1 heads go for 1500+, their cam is alittle expensive but most cams are ~240+. Coated Hooker LTs will cost you about 600$, the factor in 100$ for a custom y-pipe. Borla/Corsa, most high quality cat-backs are over 500$. TBs are usually 300$+, CAI - 160$+. You can save on the PCM program by going with PCMForless, then theres miscellaneous parts like plugs, gaskets.
When its all said and done most head and cammed LT1s with stock bottom ends have more than 4600$ in them.
If anyone would get that kit I'd suggest getting their longtubes and the ZZ-9X cam (239/239) that way you can make 400hp at the rear wheels The LTs are 25$ more and the cam is the same price.
Old Feb 11, 2003 | 10:44 AM
  #38
jmzlt1's Avatar
If you go with tpis long tubes, make sure you skip the y-pipe. The y-pipe has lots of fitment problems and isn't exactly a free flowing design. I had to hack off about 3 inches to get it to fit right and it hung too low to the ground. Not to mention the y area was more like a T pipe! Nothing beats a custom y-pipe. Headers fit great though.
Old Feb 11, 2003 | 04:22 PM
  #39
BUBBA's Avatar
Originally posted by latinspice-94T/A
Listen to those of us who made the mistake of putting in a puny cam in our cars. Do not waste your time! You will be very unhappy.
I have the Crane 210/224 cam and it really sucks big time. Considering I have a mild port job and bigger valves and I'm only making 303 rwhp should tell you something. On the other hand, it was on the same dyno a friend of mine with an 01 A4 SS with HPP+, Shorty headers, intake, and full exhaust put out similar numbers to me shoudl tell you something...
still, go for a bigger cam.
If you're only putting out 303 RWHP, I doubt that it is the small cam that is holding you back. I have seen 360+ with that cam, LTs and dyno tune. I believe Carl97SS had those numbers before he went to a 396.JMHO
Old Feb 11, 2003 | 04:42 PM
  #40
latinspice-94T/A's Avatar
I know BUBBA. Its just that is is hard to accept that my heads were probably ported all wrong..
I also haven't dyno tuned it... it just has a pcm for less program which gave me 0 power. It fixed some tranny/shifting issues and created others. I'm having a local friend tune it for me.
Old Feb 11, 2003 | 05:04 PM
  #41
BUBBA's Avatar
As I recall, Carl had his heads CNC'd, but he made the real gains by going from an Ed Wright's mail order tune 327 RWHP to Ed's Dyno tune which took him up to around 365 RWHP thereabouts.
I guess it takes a lot of tweaking here and there to have both a daily driver and a low 12 high 11 ride. But with the right combo (even with a mild cam) I belive it can be accomplished.JMHO
F'n1996Z28SS
Aug 23, 2023 11:19 PM
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
