need more power in the low and mid ranges
Old Nov 28, 2003 | 03:24 PM
  #16
QCKZ28's Avatar
1. long tubes rob a small amount of low end torque and gain around 30rwhp peak.....
2. shorties do not flow better at high speeds (rpms)....shorties arent much better than manifolds......
3. if you want more low end torque with a stock lt1, a torque converter will solve your prolem a PI 2800 will work perfect with a set of 3.73s. you will have more low end torque than street tires can handle you will need drag radials to hook.
jesse
Old Nov 28, 2003 | 03:31 PM
  #17
rskrause's Avatar
Moderator
As others have said, gears and converter rather than engine mods seem like the best bet. Headers will help. As Mike stated, long tubes tend to improve low end and mid-range torque better than shorter headers.
Rich Krause
Russ95Z28
Apr 23, 2015 01:55 PM
carl.froehlich
Mar 13, 2015 12:38 AM
XtremeLt1
Sep 13, 2002 08:50 PM
Brian Demeter
Aug 17, 2002 08:07 PM
