Need LT1 dual intank fuel pump
Old Mar 29, 2004 | 04:41 PM
bad95formula's Avatar
Anybody know where I can pick one up from. The last couple times I contacted Racetronix, they weren't making them so I either need to find someone that does make 'em or make one myself. If anyone has put one together themselves, please chime in cause I could use the tips. Thanks guys.
Old Mar 29, 2004 | 10:56 PM
anyone?
Old Mar 30, 2004 | 06:21 AM
IDOXLR8's Avatar
Re: Need LT1 dual intank fuel pump
What kind of setup are you running?
Old Mar 30, 2004 | 11:09 AM
I'll be running a 355 with a vortech s-trim at 13-14 lbs of boost. I'll probably upgrade to a t-trim later on but I only want to do a fuel system once. I'm running 72 lb injectors with a low impedance box. Any suggestions?
Old Mar 30, 2004 | 11:25 AM
IDOXLR8's Avatar
I am currently running a twin intank setup. It was a pain to custom make a kit but well worth it. How did you come to the conclusion that you needed 72 lb injectors? An alternative to running a twin intank would be running a Kenny Bell boost a pump. I believe Rskrause has had good luck running that setup.
Old Mar 30, 2004 | 02:42 PM
I figured that 72 pounders would flow enough fuel to cover the amount of boost i'd be running now and any added boost id run in the future. What injectors are you running? What made putting together your dual intank pump such a PIA? Thanks for your help.
Old Mar 31, 2004 | 07:33 PM
Any thoughts on this fuel system from Speed Inc.?
Fuel System
Edit: Specifically, kit 1
Old Apr 1, 2004 | 06:17 AM
IDOXLR8's Avatar
I am running 83 lb injectors.
The biggest task was making a y-piece that to connect both the fuel pumps at the hanger. Everything else is pretty much cake work.
Old Apr 1, 2004 | 06:21 AM
IDOXLR8's Avatar
Fuel System
Personally, I am not a big fan of Aeromotive pumps. If you decide you are going to sump your tank than I would recommend going with a Weldon pump. Also I would highly recommend getting a voltage regulator. Just so you know big external pumps are extremely loud.
Old Apr 1, 2004 | 12:05 PM
Ive heard both good and bad things about Aeromotive pumps. How much of a PIA would it be to sump the tank? I really want to put together something soon but I dont want it to be the biggest hassle in the world. Maybe i'll go ahead and pt together a dual intank system. I work in a weld shop so fabbing up a y piece may not be a big issue.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
