Need a Little fuel Advice
Ok so I am working on Fixing everything wrong with my car. I Have a 94 Z28 A4. I Need to find out exactly which fuel pump and Regulator I need to buy, and where. I dont want to go cheap with it so I figure a 235L/hr. I will eventually go with 383 le2 or le3 setup. I also just bought a Race Trans and Need to find out which Poly Mount would be the best because I don't want to go back to the Stock mount, I've heard bad things about it.
Thanks in Advance for the help
Re: Need a Little fuel Advice
go with the walbro 255l/hr pump, i jsut installed it and its wonderful. If you really want though u can spend another hundred and get the racetronix kit which will probably help you out in the long run when u get that 383.
As for the mount, jsut goto autozone and pick up an energy suspensions poly mount and it will be fine. just make sure to torque it down all good and such to teh specifications and you shouldn't ahve any problems, and hopefully no extra road noise (i didn't ahve any from mine). Be also remember that the mount will take a couple days to get broken in and might sqeak or make a little noise for the first week or so.
P.S. if you look to the left of this thread where it says ads by google, it ussually has walbro pumps listed there for "low prices".
