Need injector advice!!!
Old Dec 30, 2003 | 09:59 PM
GpMike24's Avatar
i just got my car back and it seems to like hesitate, or almost cut out and stuff around 4500 or so. I thought it could just be lack of fuel. It pulls fine in lower rpms just up high starts to stutter. I just had alot of work done and the mods u can see in the signature. Problem is that i have stock injectors. SHOULD new injectors and fuel pressure regulator seem like a solution???
just got my CC306 and bored over .30 and then all internals changed out.
Old Dec 31, 2003 | 01:17 AM
GpMike24's Avatar
ttt
Old Dec 31, 2003 | 01:39 AM
aram's Avatar
scan your car and check the injector duty cycle and see if they are over 100% a decent amount of the time.. that will let you know if the injectors are maxing out. I had a problem though with my car cutting out at higher rpms and it was a failing optispark though.. threw a code also (lo res pulse).
Firechicken350
Jun 6, 2015 11:25 PM
Jun 6, 2015 08:27 AM
z28cam1993
May 29, 2015 10:17 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
