Need immediate help guys...... inside please Long ... Sorry:(
Old Feb 24, 2003 | 01:03 PM
  #16
smacz28's Avatar
Yeah thats kinda what I figured. But I wasnt sure if the battery could cause the lights to flicker after the car was started cause I assumed that then the altenator would make the difference. It is probably all to me leaving my lights on that one time coupled with the fact that I dont know the battery's actual age. Looks like I will be buying an Optima Red Top. It probably also didnt help that I had bent the post after my first TQ converter launch....... didnt realise I had a broken battery tray back then Battery it is then..... Thanks Guys
Shawn
Old Feb 24, 2003 | 01:11 PM
  #17
gd1996ss's Avatar
Check all your connections to the battery and to the altenator. Sometimes they get corroded or dn't fit on just right and won't charge fully. A bad battery will make it look like the alt is not charging well, but a bad battery can kill the alt also. With the broken tray it might have shorted something out also.
Old Feb 24, 2003 | 01:16 PM
  #18
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
It could also be a slipping belt
Old Feb 24, 2003 | 01:22 PM
  #19
smacz28's Avatar
Well the battery is definitely on its way out if it was at 10.17 volts and they say 10.5 is what they consider questionable. How would a belt cause this or is that sarcasm Trey???
Shawn
Old Feb 24, 2003 | 01:26 PM
  #20
treyZ28's Avatar
Shawn
well, on my home from michigan, the roads were so bad my belt was CONSTALY soaked in water. when the belt is wet- it has less "grip" and hence slips on the alternator and doesn't spin it.
I didn't read this whole thread, just the first few replies
Old Feb 24, 2003 | 01:32 PM
  #21
smacz28's Avatar
OHHH :P Cool.. I just wanted to make sure, since most of your advice tends to be right on But since you didnt read the whole post...... I swear Just Kidding
Shawn
Old Feb 24, 2003 | 01:35 PM
  #22
treyZ28's Avatar
Shawn
it might not just be from wetness too-
lose alternator mounts, stretched (old ) belt or even spilling a quart of mobil one motor oil on there ( dont ask how I know)
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Jul 20, 2002 06:08 AM
