Need idle help
Old Aug 1, 2021 | 12:10 PM
KYWes's Avatar
Need idle help
Often after driving when I come to a stop the idle will be 500-1000 rpm too high. If I sit long enough it will gradually come down on it's own. Sometimes I can blip the throttle and it will settle down where it should be. Otherwise the car runs fine. Oh and this is with A/C off. I've checked and set my TPS position/voltage and the IAC is in the right range at idle. I've checked for vacuum leaks and found none. I'm a bit befuddled as to what else to look at. Give me some direction please.
Old Aug 1, 2021 | 12:57 PM
Re: Need idle help
If it recovers with a blip of the throttle, sounds like the blades are possibly not closing fully when you let up on the pedal slowly to roll to a stop. While it’s idling high at a stop, get out and check the throttle/cable/quadrent for sticking.
Old Aug 2, 2021 | 07:12 AM
KYWes's Avatar
Re: Need idle help
I'll do that.
94magh
Oct 30, 2013 11:55 PM
Slick_Sammy
Classic Engine Tech
Apr 27, 2007 08:31 PM
blackztpi
May 19, 2006 11:28 AM
Fastbird93
Nov 24, 2004 04:10 PM
Deenasty
Jun 15, 2004 09:11 PM
