need ideas on my starter problem
Old Jun 29, 2004 | 10:50 PM
amean94ta's Avatar
Lightbulb need ideas on my starter problem
I have been racking my brain! I am sure its somthing stupid but ok basic layout 396 13.6:1 compression the stock starter would not turn over the motor so i get a high tq 1.9 hp with 222 ft lbs of tq.
I put it on with no shims the car starts and starter keeps running.
So i figure i need to shim it so i put (2) 1/32. Still does the same. So i keep adding 1 shim at a time till i get way out and still does the same. Has anyone had this problem and what do i do? The only thing i can think is the return spring on the bendix was no good from the start and for me to send it back and get a new one
please give info even if you think it wont work
Old Jun 30, 2004 | 07:02 AM
amean94ta's Avatar
ttt
Old Jun 30, 2004 | 07:40 AM
93transam1234's Avatar
I am not sure what the problem is but i know auto zone or pepboys can test the starters out side of the car, that way you can see if it gos back into place when it isnt installed in your car, try calling the company you got it from and ask them, maybe they even know what shims to use
Old Jun 30, 2004 | 07:59 AM
Are you sure you have the leads on it correctly?
Old Jun 30, 2004 | 05:45 PM
amean94ta's Avatar
i was told that i have the two small wires on the silinoid and they both should not be on there to take one of and it will work right but where do i put the other one
Old Jun 30, 2004 | 06:23 PM
That's why I asked. There should only be one small lead on the starter-the purple wire from the ignition switch. Of course, the large positive battery cable should be on there.
The small black/white wire that is in the same harness, is a PCM/sensor ground wire that goes to a stud on the block above the starter.
Old Jun 30, 2004 | 10:09 PM
amean94ta's Avatar
thanks it would not start with it off btw it sounds like a monster cant wait to hit the street
Klypto
Mar 9, 2015 04:25 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
