need horsepower estimate.......
Old May 5, 2005 | 08:06 PM
F-body Scotty's Avatar
Hey all,
i just bought me a remanufactured LT-1 and im having some things done to it before i get it.....here's the deal......if i remember correctly, a stock 93' LT-1 pumps out 275 HP and 325 ft-lbs of twist......
this is what im having done to the motor:
Upgraded piston rings (no HP)
upgraded bearings (no HP)
3 angle valve job ( ? )
stepped up cam (dont know measurements assuming just more aggressive than stock)
ported / polished heads
thats basically it for the motor itself......now onto the bolt-on's i already have for the car.......
SLP 1&3/4" headers
high flow CAT
3" intermediate pipe going to spi-tech muffler with 2 1/2" outlets
K&N air filter
throttle body air foil
hypertech chip
160 deg t-stat
MSD blaster coil ( no MSD box, i know i know)
24 lb fuel injectors (stock 22 lb)
So.....thats the jist of it.......i personally think i should be pumping out in the realm of 350-380 HP.......but , hey.....what the hell do i know.....
opinions?
thanks.
Old May 5, 2005 | 08:44 PM
Tibbys96Z's Avatar
Re: need horsepower estimate.......
if you are talking about power to the ground I'd guess 320rwhp/345ftlbs
Of course without knowing the cam specs, type of transmission, tuning....It's just a guess...
Old May 5, 2005 | 11:30 PM
MEAN LT1's Avatar
Can we get those from you please, It woul dmake it alot easier to figure out.
Old Aug 16, 2005 | 08:34 PM
dont know specs on the cam, but i was told its a comp cam and its the next step up over stock.....
by the way, its been a while since i posted this, and the motor has around 375 miles on it so far and its kicking hard...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Aug 24, 2015 06:41 AM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
