Need a high performance lifter
98% of the hydraulic roller lifters out there are made by Speed Pro. They sell them to just about every cam maker out there. The older "Comp" hyd-rollers even had Speed Pro stamped on the link bars.
To answer your question, you could go with the CC 850-16 as was mentioned or go with Crane or Crower. I wouldn't lose any sleep over the choice though.
-Mindgame
-Mindgame
As far as comp goes the 850-16 is a good OE replacement lifter for our cars probably a little better than stock. If you are looking for a higher rpm hydraulic lifter (anti-pumpup) the comp Pro Magnums 875-16 are probably as close to the R's as you will get.
I'm looking for new lifters since with my new setup, I am pushing 394# of open seat pressure and don't want to collapse one of the lifters that were previously in the car. What would you recommend? I'm also going w/ cmotorsports chromoly pushrods for extra insurance. Should I run 7.200" or go with 7.150" since my heads are milled 0.02" to 0.03"?
The 875-16 are the same R lifters, so good luck finding a set.
As for the pushrod length, get a checker and measure before you buy them. My block is milled 0.02" and the cam is a small base circle. I used the checker and found that the best length is 7.2"
Jeff, I went with Crane Cams replacement set. Their "high performance" set was $560!!!! I paid $165 from Summit for the replacement ones, which is all I really need. You might be bumping a much bigger lift than me though, so you should talk to some shops to see what they recommend.
cmsmith
Apr 1, 2015 09:29 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
pnbarbee
Jul 9, 2002 06:35 AM
Question is for Dave Gill
