need help w/part number
Old May 10, 2004 | 02:57 PM
The Cartel's Avatar
Question need help w/part number
What is GM part number 12551483?
Are these Lt1 heads? If so what year?
Thanx Jason
Old May 10, 2004 | 03:16 PM
DESCRIPTION: VALVE SPRING
This single valve spring is use on 1996 LT4 Production Corvettes and ZZ4 crate engines. Technical Notes: Single spring with 1.32" O.D. and 1.22" solid height. The pressure at installed height IS 101# @ 1.78" with 332# the average rate of pounds per inch. Use with retainer P/N 10168424.
Old May 10, 2004 | 03:57 PM
Mtrhds94Z's Avatar
That would be one spring of the LT4 spring set, which is GM p/n:
LT4 Valve Spring Kit 12495494 [16/ 12551483's]
Also that p/n given for a retainer is an LT1 retainer [one] the LT4 retainer set is:
LT4 SB Chevy Valve Spring Cap Kit 12495492 [16/ 10212808's]
Old May 10, 2004 | 04:59 PM
The Cartel's Avatar
You guys rock. Where do you go to decode part numbers?
Thanx again, Jason
Old May 10, 2004 | 05:22 PM
I just plugged in your part # at http://gmpartsdirect.com/ , but I have a lot of part numbers listed on my site.
Old May 10, 2004 | 06:42 PM
The Cartel's Avatar
thanks again, shoebox
Jason
Boss002
Jan 20, 2016 12:17 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Catmaigne
Jul 14, 2015 05:17 PM
gelbza
Jul 12, 2015 08:10 AM
