NEED HELP!!! valvetrain question
Old Aug 30, 2007 | 04:45 PM
xxxtreme36's Avatar
i have a brand new .060 fully forged lt1 with the canton oil pan and ported lt1 heads with all new valvetrain.....i finally got the car to start and idle for the first time lastnight. My question is, it seems like there isnt much oil in the valvetrain area.....other than the oil that was added... Does the car need to run for awhile?? the guage reads around 60 when idling but has never been up to temp. I have a stock dipstick and tube and it doesnt seem like its really reading that theres much oil in it.........but i know theres atleast 5.5 quarts...... Any suggestions would help
Old Aug 30, 2007 | 05:09 PM
BUBBA's Avatar
I'm sure someone else knows, however perhaps the Canton pan is deeper or shaped differently and the std. dip stick will not work. You also might check with the place you got the pan from. JMHO
Old Aug 30, 2007 | 06:19 PM
xxxtreme36's Avatar
thats true..............chime in people i need some expert advice......or experience
Old Aug 30, 2007 | 07:15 PM
Voridaeus's Avatar
There's enough material to overbore .060"? I didn't think you could do that much?
Old Aug 30, 2007 | 09:44 PM
jonlil77's Avatar
Oil level on dipstick
I run 5 qts in the pan, plus filter,with the 242t ,with stock dipstick you can only see a drop at the tip when you check it
Old Aug 30, 2007 | 10:34 PM
When you first crank it, you should run it at 1500-2000 PRM for a bit to get oil up to the heads. It might take a minute or two.
Old Aug 31, 2007 | 09:09 AM
xxxtreme36's Avatar
yeah as long as you have the block sonic checked before you do the boring theres usually enough..............ill have to try and see if what you say works shbox...........keep the help and possibilities coming.....
Old Aug 31, 2007 | 10:58 AM
JP95ZM6's Avatar
The dipstick can be very hard to read with a Conton. I put 5.5 qts in my 242-T, and the dipstick would always be wet to the low mark on one side, but only wet at the tip on the other side. Low oil light would occasionally come on. I added another 1/2 qt, and light never went on, but dipstick showed exactly the same. Added another 1/2 quart, dipstick still only gets wet at the tip on the side that shows less. So, I don't think the dipstick is even touching the oil at 6.5 qts, IMO it's just getting wet from the oil in the tube getting smeared onto it. I don't trust the stock dipstick at all.
Old Aug 31, 2007 | 03:45 PM
xxxtreme36's Avatar
ya i just drained the oil, cut the filter open and all looked well..........def not enough oil in it though...this time ill make sure theres 6.5 to be safe and the cars never ran for more than a few seconds so hopefully when the oil heats up it goes into the valvetrain
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
