Need Help and Totally confused
Old Aug 25, 2003 | 06:28 PM
Geoff Chadwick's Avatar
Question Need Help and Totally confused
At the request of someone looking at the car, they offered to buy it, but wanted to see how it ran, to the end of the street and back. So we did. This is what we found...
Under no load, free revving, there is a deep clacking from the engine, and it sounds like the intake manifold or below, but I could be wrong, it is rather loud. Does not sound like a rocker, it is much too loud. It sounds like a bad rod bearing, or perhaps a collapsed lifter(which are Comp Cams type R with less then 3000 miles on them). Also when the throttle is blipped in neutral, it makes that funny "clackity clackity clackity" really quickly as the rpms fall down as bad rod bearings tend to sound like... But under load, ala 75% throttle and above and more then 4000rpm in gear, the clack is completly gone and the car produces a bit of power, but we didnt rev it past 5k or full WOT so dont know if it's loosing a lot of power on top end... but while driving around at low throttle and rpm in gear, it feels like it's stumbling and has a leak or something because it barely runs. So, life continues to be stupid! Any ideas once again? Is this just a really strange rod bearing that has gone and is tormenting me, or could it be something else?
Nayr
Mar 3, 2023 08:34 PM
magman
Apr 15, 2016 03:08 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
