Need Help, thermostat housing.
Old Sep 11, 2008 | 08:26 PM
karpetcm's Avatar
well today i went to install my 160 Thermostat and i took off one bolt passenger side to give you an idea but the drivers side one snapped off. All i see is thread now maybe half an inch. To say the least even the one on the passenger side that i took off is very rusty. Im assuming thats how the other one is maybe the reason why it snapped off. Is there any method or anything i can do to get this bolt of again all i see is threads and its on there tight not loose. Thanks in advance
Old Sep 11, 2008 | 08:51 PM
stvski80085's Avatar
Try to get some vice grips on it and remove it. Then get a new bolt and you should be good. They also have a device but i forget what it's called but it will back that out. You drill a small hole in the bolt and use the backout to remove it. Maybe soak it in some liquid wrench first if its real bad.
Old Sep 11, 2008 | 09:20 PM
PB Blaster and one of those tools that grips protruding, broken bolts.
Jeff1904
Jun 5, 2016 05:00 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
VetteThreat
Jun 18, 2002 01:53 PM
