need help with TFS heads
Old Jul 23, 2005 | 06:28 PM
Gearhead6s's Avatar
I am ready to install my heads and i need to know for sure if they are interchangable between each side of the motor. i am 99% sure they are and they have holes on each end for the steam pipe, but i noticed diff castin numbers. i am thinking that the numbers are just for production run info and and nothing to do with the part numbers. am i right? cna i throw either head on either side?
Old Jul 24, 2005 | 01:52 PM
SStrokerAce's Avatar
Re: need help with TFS heads
Yep you can... just look at the ends of the heads and if they have a plug in the holes on the ends then install that end on the front.
Bret
Old Jul 24, 2005 | 04:59 PM
Gearhead6s's Avatar
Thanks buddy. I thought so.
Old Jul 25, 2005 | 02:24 AM
hvyss's Avatar
Just remember that the temp sensor hole on the TFS heads 1/2 inch. the sensor is 3/8. Will need to get a reducer to adapt for the sensor. Found this out the hard way on a buddie's TFS head install on his 95Z. Good luck
HVY SS
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
twistedwedge
Jul 27, 2002 01:54 PM
