need help with TB disassembly
Old Nov 17, 2004 | 02:01 PM
92LT1RS's Avatar
Alright, so I've got the TB stripped down to just the body itself with the throttle blades and shaft still in it. How do I get the shaft out? There is a keeper on the end of the shaft where the TPS sits, but I'm afraid if I start prying on it or something I'm going to destroy it and be out a throttle body. Any suggestions?
Old Nov 17, 2004 | 03:31 PM
crash4cyl's Avatar
Re: need help with TB disassembly
I know you need to get the throttle blades off, then you should be able to slide it around enough to get the keeper out without ruining it.
Chris
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
Javelin3o4
Jun 25, 2004 01:54 AM
bad_zr1
Apr 27, 2004 11:34 PM
bad_zr1
Apr 19, 2004 08:02 PM
