Need help surging idle from cam swap
Old Jun 24, 2006 | 12:06 AM
93redlt1's Avatar
my friend swapped in a hotcam from the le2 cam with le2 heads and now the car is surging all over the place so we took it apart to make sure the timing gears were lined up correctly and they were. the opti is a 95 and up and in proper working condition because it was working b4 car was taken apart. The chip has been retuned but somehow the car is still running very rich as if timiming is off somehow. My friend is ready to push it into the canal so any help is very appreciated.
Old Jun 24, 2006 | 07:56 PM
redsick93lt1's Avatar
Re: Need help surging idle from cam swap
it also seems as if the car is missing. I just finished fooling with it an hour ago. we have tried 2 optis with no luck. Could bad valve adjustment be a cause of this.
Old Jun 24, 2006 | 11:58 PM
sam pace's Avatar
check your vale lash you could have a rocker too tight.
Old Jun 25, 2006 | 05:10 PM
OBE1 95Z28's Avatar
Check all the obvious stuff first:
vacuum leaks
wires properly seated
no burn wires
fuel pressure
Could also need to be tuned.
Old Jun 25, 2006 | 07:04 PM
ok we checked the valves, vacuum leaks. we also checked the plug wires although i may recheck those. The car now idles well but pops now and then after we disconnected the iat sensor. So i think it is either a timing problem and/or wire problem.
Old Jun 25, 2006 | 07:18 PM
is there any way that the timing can be advanced with an external msd product such as the timing advance unit that they advertise
Noenav
Mar 1, 2019 07:38 AM
grgguy
17
Feb 23, 2015 07:57 PM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
