Need help with replacing the clutch MC...
Old Mar 26, 2004 | 01:49 PM
97 Camaro SS's Avatar
OK, this is my 2nd failed attempt at getting this SOB out. I dropped the lower dash and kick panel, pulled the clip and pushrod off the clutch pedel, and the two screws off the firewall. I can get the studs and MC to wiggle, but it will not move. What is the deal? It seems like the studs hit the back of the brake booster. Am I missing something?
Steve
Old Mar 26, 2004 | 03:32 PM
rmackintosh's Avatar
just did this two times in the last week.....
no...the "stud" is a piece of rod stock bent into a "U" and the open end of the U was too wide....WAS A B&$@TCH to pull out....had to tug and tug and tug....much blood loss....when you get it out....match the U up to the firewall better before putting it back in....you will be happy you did
Old Mar 26, 2004 | 03:35 PM
OK, so it is just a bitch to get out.
What about the brake booster? Is that not in the way?
Thanks,
Steve
Old Mar 27, 2004 | 12:42 AM
Its not in the way of getting it out.....just enough to make it a REAL PITA to get out!
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
