Need help removing knock sensor....under car now!
Old Feb 28, 2004 | 12:21 PM
JJ's95B4C's Avatar
I'm working on getting the heads off right now and am trying to drain the coolant from the block. I got to the knock sensor, and i turn it, but the inside part just spins. I'm guessing this isn't supposed to be this way? How do I get this off?
Thanks!
Old Feb 28, 2004 | 02:22 PM
carlos64030's Avatar
Break off the large round portion of the knock sensor and use a pair of vise grips to remove the remaining threaded portion.
Old Feb 28, 2004 | 03:32 PM
JJ's95B4C's Avatar
Does that mean that i need a new knock sensor? What do you mean by break off the large portion?
Old Feb 28, 2004 | 11:25 PM
JJ's95B4C's Avatar
TTT
If I turned the gold part of the Knock sensor, does that mean that I broke it and need a new one?
Old Feb 28, 2004 | 11:34 PM
Originally posted by JJ's95B4C
TTT
Hard to say. You could test it by using a meter to measure in the range of 3300-4500 ohms from the center terminal to ground (or outside metal shell of the sensor).
97SSdude
Dec 31, 2014 07:43 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Lions3
Apr 11, 2003 10:55 AM
