Need help quick...battery ground/starter cable
Old Dec 16, 2007 | 05:44 PM
a walker's Avatar
Where does the negative cable ground to the engine block? Its the cable that is routed with the positive cable for the starter. Is it the stud that's just below #6 spark plug and just above the knock sensor?
Old Dec 16, 2007 | 05:56 PM
mdacton's Avatar
a stud on one othe motor mount bolts
rcantrellz28's Avatar
Yes thats where it is.
Old Dec 16, 2007 | 06:24 PM
a walker's Avatar
Ok, that explains that then lol. I need to pull the bolt and replace it with a stud.
So what goes on that little stud I mentioned before?
Old Dec 16, 2007 | 07:11 PM
mdacton's Avatar
little tiny one? 3/8" hex head on it? probly one of the plug wire holders
Old Dec 17, 2007 | 03:12 AM
a walker's Avatar
Thanks for all the help guys. I figured out what that little stud was for - the pcm ground..
I got to fire the car up tonight for the first time after the engine swap. I'll have a post with a video within the next couple days.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
