arp head bolt torque
Old Dec 16, 2007 | 06:58 PM
RallyBoy1's Avatar
Has anyone used this method of tightening head bolts?
This excerpt is from arp's website.
1. The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
Old Dec 17, 2007 | 08:24 AM
RallyBoy1's Avatar
no one has ever tried this???
Old Dec 17, 2007 | 08:54 AM
rskrause's Avatar
Moderator
I do it three times. I don't have the patience for five and three gets you 95% of the way there.
Rich
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
