Need help QUICK!!!
Old May 17, 2003 | 10:37 PM
prowlingLT1's Avatar
Need help QUICK!!!
Alright I just got my car back together and it cranked right up. But I think my timing is way off because my headers started to glow red. And it seemed to be a little slow reving and a little sluggish. What could cause this? how could it be fixed? Could it be the computer or the timming chain be on wrong? Also there are three places on the back of the optispark that the dowel can go which one is the right one and if it was in the wrong one would it still crank.
any help would be appreciated Thanks Brian
Old May 17, 2003 | 11:20 PM
You should have asked about the opti sooner.
This is how it should go. It is possible to get it on wrong, but may not run. You might also have plugs wires on incorrectly.
If you are tooth or two off on the cam sprocket, it may run, but not very well at all.
Old May 17, 2003 | 11:40 PM
will the dowel even fit in the wrong hole, if it does will it run.
Old May 17, 2003 | 11:53 PM
People have gotten the dowen in the wrong hole. I am not positive whether it will run or not. It usually causes some popping or backfiring.
Old May 18, 2003 | 12:02 AM
does it sound like timing to u. if so could it be the computer with the stuff i have. Or do u think its some where around the distributer or timming chain. Also if the opti was bad could it cause the problems im having
Old May 18, 2003 | 12:10 AM
If it ran ok before you did the work, it is probably something you did. Check easy stuff first, like vacuum hoses and all connections you touched. If you have some way of monitoring it with a scan tool, that may tell you something.
Don't think it is a computer problem. Nothing you did should have affected that. Last resort, take the front back apart to verify that you have everything lined up correctly.
Old May 18, 2003 | 12:30 AM
its not throwing any codes and it is a whole new motor so thats why i was wondering. I also removed the air pump will that affect anything. thanks
Old May 18, 2003 | 08:29 AM
As long as you closed the AIR fittings to the exhaust, there should be no problem with it.
Old May 18, 2003 | 12:06 PM
If the opti was going out would it cause the timming to be off, ive never heard of it doing that.
Old May 18, 2003 | 12:54 PM
ttt
Old May 18, 2003 | 03:07 PM
anyone
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
