Need Help with plug/wire install
Old Jun 22, 2003 | 11:17 PM
CeeBee94Z's Avatar
Does anyone have an install page for the Taylor OVTC wires for our cars? I got all of the wires all run and set and everything, then when I went to get the damn boots on, I couldn't slide them on. Is there an easy way to do this?
Also, do any of you have recommendations for doing the plugs and wires on the passenger side of the car? Should I remove anything in particular? It looks like it is gonna be a pain so I didn't even start it yet...any help is appreciated
Old Jun 23, 2003 | 01:22 AM
Wildwill532's Avatar
I have read people use a bar of soap on the end or dawn dishwash soap i would also think the some ky jelly or vasaline should work too!
Old Jun 23, 2003 | 05:13 AM
Hyperspeed97z28's Avatar
take the alt out chris..... give ya some room
Old Jun 23, 2003 | 06:23 AM
Jon97Z's Avatar
Try this site. Click under 'projects' and there's an install page there.
http://Ken.lowrance.com/
Also, try searching this site under "OVC wire." This has been mentioned quite often.
Old Jun 23, 2003 | 07:55 AM
teke184's Avatar
remove the alternator, and remove the passenger motor mount bolt. then jack the motore up about 2 inches...
i was able to get to all 4 plugs from the top, and i have stock manifolds.
good luck
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
