need help please
Old Jun 29, 2008 | 03:57 PM
strokerz28's Avatar
need help please
will a 1993 lt1 out of a firebird go in a 1996 camaro z28 with no problems as far as wiring and other basicly is it a bolt in ang go
Old Jun 29, 2008 | 04:25 PM
red 95 z28 lt1's Avatar
you will need a maf sensor (i think the 93 did not have any), and a different timing cover for the crank sensor i think the fuel rail is different as to how it hooks up so you may need a 94and up fuel rail and intake manifold i think
and if you need the new timing cover then you need the 95 and up opti
Old Jun 29, 2008 | 04:32 PM
strokerz28's Avatar
well i still have my complete 96 motor for parts
Old Jun 29, 2008 | 05:39 PM
if you have the 96 motor for parts then there should be no problem, when they are side by side compare the 2 and swap the things that are diffrent
