Need help picking out injectors of new build up?
Ok i got my new cam, i am looking into getting heads right now and saving for the rotating assembly. My question is what size injectors will i need for the motor. I can buy a set of new 25# injectors for a 100 bucks or do i need to go bigger. also what brand is best of the money (im on a buget) i have heard bad things about accel when used with n2o.
here is what i am building
zz-9 cam
LT4 heads
hardcore racing 355 rotating assembly
4 bolt LT1 block
zex wet kit for a 125 shot
Also what stall speed do you think i will need?
thanks for any help you can give.
zz-9 cam
LT4 heads
4 bolt LT1 block
Re: Need help picking out injectors of new build up?
Since you are using a wet nitrous system, it will have no affect on your injector sizing or choice.
Bearmans
Dec 3, 2014 05:28 AM
