need help with oil leak
Old Oct 1, 2005 | 06:13 PM
colossus's Avatar
(94 formula) i had to drop the oil pan down a little bit so i could get my timing cover off, and now i have horrible oil leak. I cant find exactly where its coming from, but the oil is dripping down the side of the oil filter, so i dont know if its coming from where the oil filter screws into or from the pan. Has anybody else had this problem or heard of this problem from just dropping the pan? Also it ran with no leaks at all for a few weeks then all of a sudden it started leaking bad.
Old Oct 1, 2005 | 06:38 PM
colossus's Avatar
Re: need help with oil leak
ok so just found exactly where its coming from. it is coming from the pan and its leaking from about an inch along the pan. what do you guys suggest that i do about this?
oh and yea i torque to spec
Old Oct 1, 2005 | 07:50 PM
colossus's Avatar
im thinking that the gasket got moved over the the side right there. so since i'll probably be having to drop the pan again, is there any way that i can get to those pan bolts with the two coolant lines running right next to them, or am i going to have to take that line out again?
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
