Need Help/Major Starting Issues
Old Jul 10, 2010 | 08:54 PM
bds001's Avatar
Ok I've got a '96 Z28.
When trying to start the car, it takes many attempts to get the motor to start, sometimes 10+ key turns while letting it crank about 2 seconds each time.
Most of the time when it finally starts up (it does start up every time it just takes a while), it has to build up to idle real slowly, running real choppy and rough about 300-400 RPM below normal idle. It builds up to normal in a couple of seconds and then idles fine.
When running steady through the RPM range, theres a real bad lag at about 3000 RPM before it starts revving back up normal again. It also doesnt seem to run with as much power as it used to.
Replacing plugs, wires, and opti didn't do anything to help.
Please give me any and all ideas that ya'll may have. This thing is driving me crazy. Thanks!
Old Jul 10, 2010 | 09:08 PM
Any scan data or trouble codes? What is your fuel pressure?
Old Jul 10, 2010 | 09:55 PM
bds001's Avatar
Been trying to find someone local with a fuel pressure gauge. Is there somewhere to rent one or are they available from loan from an Autozone/Advance?
Do have SES light, but havent been able to make it to get it checked for codes yet. Hopefully I can get that done Monday. Probably should have started with that, but it seems like when I had it checked before it was something irrelevant.
Old Jul 11, 2010 | 09:16 AM
Unless you want to get nickle and dimed to death by dealers and shops, you need to get your own tools. A fuel pressure test gauge is no more than $35. A cheap OBD-II code scanner is under $50. They will pay for themselves many times over.
When you try to start it, will it start easier if you put the throttle on the floor BEFORE you turn the key to start it, and hold the throttle on the floor until it starts?
Old Jul 11, 2010 | 10:19 AM
bds001's Avatar
Just tried this a few minutes ago, and it didn't start any easier than with no throttle.
Old Jul 11, 2010 | 12:57 PM
bds001's Avatar
Ok I had forgotten that there was was a Hypertech tuning on the car (came with it when I bought it).
I just hooked up the unit to the car and put all settings back to stock, and the SES light doesn't come on anymore.
Still have the same starting issues however.
Old Jul 14, 2010 | 03:01 PM
bds001's Avatar
Fuel Pressure when key is in on position: 7-8 PSI
Fuel Pressure while motor is at idle/light driving: 30-32 PSI
Fuel Pressure at WOT under load: 20-22 PSI
anyone tell me what to do based on that?
Old Jul 14, 2010 | 03:21 PM
97FormulaWS-6's Avatar
Fuel Pump is shot. You should be in the 42psi range.
Replace your Fuel Pump and Filter. Should solve your issues.
Old Jul 14, 2010 | 05:13 PM
Try the filter, then the pump.
Old Jul 14, 2010 | 05:39 PM
bds001's Avatar
replaced the filter a couple of weeks ago. Didnt change anything
Old Jul 14, 2010 | 06:43 PM
Ah, would have been nice to include that info before someone went to the trouble to suggest it.
Old Jul 14, 2010 | 09:28 PM
bds001's Avatar
Sorry. Forgot about it til it was mentioned or else I would have
Old Jul 15, 2010 | 08:04 AM
LT1_Z28_1994's Avatar
Hard starting can be a sign of a bad fuel pressure regulator. Check it out before changing the fuel pump...
Old Jul 15, 2010 | 10:46 AM
bds001's Avatar
is the only way to check the FPR to check the vaccuum line for fuel or the smell of fuel?
Old Jul 15, 2010 | 01:58 PM
bds001's Avatar
is getting a new fuel pump from a parts store a bad idea?
