Need help on installing trans mount
Old May 23, 2004 | 12:16 PM
ping0317's Avatar
I know it is easy installing a trans mount.... Removing the cross member, do I need to have something holding my transmission up?
Old May 23, 2004 | 12:29 PM
Robs97Z28's Avatar
yes, floor jack would be best or a bottle.
Old May 23, 2004 | 12:34 PM
ping0317's Avatar
how do you jack up the transmission?
Old May 23, 2004 | 12:51 PM
Robs97Z28's Avatar
just place it under the trans and jack it up until it takes the pressure off of the cross member. then remove everything. Out in new mount then reinstall everything.
JamesNobles's Avatar
Well put the round part of the jack on the tranny and start pumping...lol
Put the jack head closer to the rear of the tranny (towards the rear end) and jack it up enough to get reasonable clearance to replace the mount...
If you feel more comfortable, you "can" take off the crossmember leaving the jack under the tranny. Thats if you dont trust the jack....lol
Good Luck!!
james
#7's Avatar
Dont' actually jack the trans up,just support it enough to hold it where it is. And a floor jack would be best so as to facilitate any adjustments side to side if needed putting the new one in. MO
Old May 23, 2004 | 12:52 PM
ping0317's Avatar
Stupid question...when you say jack the trans are you indicating the trans pan?
Old May 23, 2004 | 12:54 PM
#7's Avatar
Hey 3 10:51's what'd we win
Old May 23, 2004 | 01:00 PM
ping0317's Avatar
thanks guys... doing it right now
#7's Avatar
You will have to.Get a 2x12 wide place between jack cup and pan long enough to go past edges of pan to help disperse weight evenly and not dent pan. And the above method and you'll be fine.
Richardan15
May 30, 2015 08:36 AM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
x7x7
Aug 15, 2002 06:49 PM
