Need help identifying problem :(
Old May 2, 2008 | 07:46 PM
Hood_Lum's Avatar
When I start my car it's fine.
I can rev it and it's fine. (well kind of, 3 of my spark plugs were loose)
When I put it into gear and start moving around 1500rpm I hear a metal grinding noise. Almost like brake pads rubbing on an extremely warped rotor.
The car moves fine and once I get past that point the noise goes away.
It's only at arond that rpm that I get noise. I thought it might be the rear tranny mount so I swapped it out but it's still making the same noise. Could it be the clutch? It catches fine and doesnt seem to be slipping at all.
Oliver
Old May 2, 2008 | 07:49 PM
The_Bishop's Avatar
Universal joints in the driveshaft, maybe? Get under there and check them out. Try and wiggle them, you're looking for any looseness or play in the joint.
Old May 2, 2008 | 07:52 PM
Hood_Lum's Avatar
I grabbed the drive shaft after I changed the tranny mount and tried to twist it with both hands. No play at all.
Old May 2, 2008 | 08:05 PM
rusnrno's Avatar
Was it out of gear with the emergency brake on when you checked it?
Old May 2, 2008 | 08:23 PM
Hood_Lum's Avatar
it was in gear and e-brakes on.
should I have done the opposite?
Kind of dangerous to be under the car with the ebrakes off and trying to move the driveshaft.
Old May 2, 2008 | 09:37 PM
rusnrno's Avatar
The E brake should be on as I stated. I just think you can get a better feel of the U-joints with it out of gear.
Does the noise go away when you apply a little brake? You might try putting it on jack stands and turn the rear wheels by hand to see if you can hear it.
Old May 3, 2008 | 11:01 AM
The_Bishop's Avatar
Has the car been sitting a while? Are the brake rotors rusty, maybe that's the noise.
Old May 3, 2008 | 02:19 PM
Hood_Lum's Avatar
The rotors looks fine. The noise seems to come from the middle of the car. Right about where the tranny is. I'm starting to think it's coming from inside the tranny.
Old May 3, 2008 | 03:30 PM
Mtxz453's Avatar
pull the cover off the rear and check your gears.
Old May 4, 2008 | 06:07 AM
Hood_Lum's Avatar
Does broken gears make noise consistantly at around 1.5k rpm?
It's been so long since I've had broken rear gears I don't remember.
I just remember everytime the broken chunk get's stuck it breaks off more teeth and jars the car. Right now the car runs pretty smooth. The sound does vary depending on the rpm. The higher the rpm the faster it sounds. Which leads me to believe it's coming from inside the tranny. I'll keep you guys posted on what I find in case this could help anyone in the future. I won't be able to look at it until middle of next week though.
Old May 4, 2008 | 06:34 AM
custom95's Avatar
i had my exhaust loosen up on me one time and the catalytic converter was actually hitting the driveshaft a little at certain rpms. it made a grinding noise and it took me forever to figure it out because at glance when the car was off it wasn't making contact, but under load it was flexing and rubbing. i noticed the converter had some spots where it looked ground down so pushed on it a bit and sure enough, it made contact with the driveshaft. it's a long shot, but take a look.
Old May 8, 2008 | 12:41 AM
Hood_Lum's Avatar
So I looked at the car today.
Everything underneath is solid. Nothing rubbing.
I've narrowed down the noise as well.
It only makes noise when the clutch is engaging.
Once it makes full contact, the noise stops.
So since it's only making noise during the engagement, does that mean my clutch is bad?
I'm not slipping at all.
Old May 8, 2008 | 03:34 AM
sl2racer's Avatar
kind of sounds like a throw out bearing.
Old May 8, 2008 | 09:03 PM
jclark311's Avatar
TO Bearing!
Old May 26, 2008 | 11:14 PM
Hood_Lum's Avatar
The center section of the clutch disk was completely ripped from the outer circle. So when the clutch was engaging the center would spin while the part with the clutch material was stationary.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
Sixer-Bird
34
Aug 31, 2002 12:59 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
