Need help ID some parts/where to get replacements?
Old Apr 4, 2004 | 02:40 PM
Dave88LX's Avatar
I spent the day yesterday out in the garage with my new Clarke 20-gallon parts washer cleaning all my stuff to get this LT1 ready to get back on the road. (No, I didn't wash any rubber or plastic in it ). Anyways, as I came across broken stuff that needed replaced, I took a pic and then drew an arrow.
What exactly is this, and can I get the replacement from GM, or Autozone, best source if you know...
Here's my $70 cabinet I bought at Home Depot, a bit better than the Lowes one. Keeping the doors closed to keep dust from getting everywhere again:
http://paradox.shacknet.nu/dave88lx/...ts/cabinet.jpg
Behold the power of Goo-Gone! There is no negative to using this correct?
http://paradox.shacknet.nu/dave88lx/...s/googone1.jpg
http://paradox.shacknet.nu/dave88lx/...s/googone2.jpg
http://paradox.shacknet.nu/dave88lx/...P%20Sensor.jpg
1993-1997 MAP sensor seal 1635948 $2.12
This is the EGR solenoid correct? I need the vac line that goes in that arrow. If it IS the EGR solenoid, then I don't need that vac line, because I'm deleting the EGR system.
http://paradox.shacknet.nu/dave88lx/...R-Solenoid.jpg
1. Need this rubber line. Is that a GM part #?
http://paradox.shacknet.nu/dave88lx/.../needpart1.jpg
2. Looking at shoebox's site, this looks like the EVAP canister purge solenoid valve, but the spacing on the 2 adjacent vac nipples look spaced differently.
http://paradox.shacknet.nu/dave88lx/...noid-Valve.jpg
This is the pic on Shoebox's site:
http://shbox.com/1/evap_sol.jpg
See how it's different?
3. This rubber elbow:
http://paradox.shacknet.nu/dave88lx/.../needpart3.jpg
4. The 2 metal rings that go on the OptiSpark here:
http://paradox.shacknet.nu/dave88lx/.../needpart4.jpg
5. This rubber elbow as well:
http://paradox.shacknet.nu/dave88lx/.../needpart5.jpg
6. The large rubber ring that seals the front cover of the water pump. Maybe I do not need it though with the CSI elec. WP? It seems to have a SMALL seal...
Lastly, I broke a couple electrical connectors in the wiring harness. Does GM sell just the connector?
Thanks!!!
Dave
Old Apr 4, 2004 | 02:48 PM
RicocheT's Avatar
That was the EGR sol. you had there.. I dunno if you can take it off without throwing a code (unless you program it out) I believe the computer looks for a vacuum. Mine throws a code b/c i had to unhook the valve. I hadn't plugged the line up with something yet to keep it from throwing one. Someone else might chime in with more knowledge about it.
Ima bout 80% positive they sell the electrical connections. They arn't cheap though. I know gmpartsdirect.com has some. But like i said.. not cheap. The one i looked at was on shoeboxs site that goes into the power window module and it was like 26 bucks. + their shipping charge.
Old Apr 4, 2004 | 02:50 PM
Dave88LX's Avatar
Thanks for the info on the EGR, I'm going to be doing an OBDII -> OBDI conversion, and will have the EGR/AIR taken out of the programming.
I did a search on "EGR" in just the Title line alone and came up with 12 pages of results, It's beyond me why people still ask the question.
I don't remember what connection I broke, but I'll find out when I go to replace my harness wire protector stuff...
Old Apr 4, 2004 | 04:21 PM
1 2 3
http://shbox.com/1/1996_evap.jpg
The EVAP solenoid p/ns are the same for all years.
4. GM PART # 10474278 opti o-ring (they are rubber)
5. GM PART # 12556257 for the whole pipe. I can only assume it comes with the rubber hose, as it is not listed by itself.
6. GM PART # 10128329
Old Apr 4, 2004 | 05:38 PM
Dave88LX's Avatar
The Opti O-rings are rubber? Must have been so hard/brittle I thought they were metal
The part the Vent hose connects to at the bottom of the diagram you posted, what is that called? It would be the part in my hand in pic one...
I just looked at the pic I took of mine, it is different than the one in your pic, and the diagram...? The hoses.
http://paradox.shacknet.nu/dave88lx/...knock/evap.jpg
Old Apr 4, 2004 | 10:58 PM
Originally posted by Dave88LX
... It would be the part in my hand in pic one...
Part # 14
Old Apr 4, 2004 | 11:38 PM
Dave88LX's Avatar
Right I got that, but I was saying in the pic that you posted vs. the pic of mine, it's different no?
Old Apr 4, 2004 | 11:47 PM
The pic of mine is different because mine is a 1995 and does not have the round vacuum switch that the 96-97s do. However, the diagram I posted was for 96-97.
Old Apr 5, 2004 | 12:42 AM
Dave88LX's Avatar
Gotcha! Yeah I saw it in the diagram, just wondering what was up with the pic itself.
I'm nearing very close to $8000.
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
stopthatman
Feb 9, 2015 09:00 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
