Need Help - Heads question
Old Dec 30, 2006 | 01:31 PM
350LT1's Avatar
Ok here is my problem,
I just had the heads resurfaced and valve job. So I have them back in place, but
I forgot what the tube that connects them looks like. I have one that makes a Long "L" with huge holes for bolts. But the bolts that fit that don't fit anywhere on the back of the heads?!?!
So anyway, does anyone have a pic of the tube that connects the 2 heads and a pic of the bolts that secures them to the heads?
Old Dec 30, 2006 | 02:21 PM
350LT1's Avatar
I have a feeling this is gonna be a long night.
Here are some pics I took.
Drawing
http://www.geocities.com/a_32p/drawing.JPG
Pipe
http://www.geocities.com/a_32p/pipe.JPG
Bolt
http://www.geocities.com/a_32p/bolt.JPG
Old Dec 30, 2006 | 02:32 PM
mdacton's Avatar
those bolts go in the back of the heads and the tube goes across the intake
Maybe you haven't done this before and can't find the hole....put your finger back there
Old Dec 30, 2006 | 04:11 PM
350LT1's Avatar
thanks for the reply.
I feel like a retard. Well after your post I took one the heads off to make sure I didn't miss anything. Boy did I miss something. I had put the damn heads on Backwards. Thats why the damn bolts wouldn't fit. I knew those where the parts , but I wanted to make sure. I am glad I did.
Now my next question. Is there 2 of those bolts? cause I only found 1.
Old Dec 30, 2006 | 07:27 PM
mdacton's Avatar
don't feel bad...It happens.
Old Dec 31, 2006 | 06:28 PM
pearlpurple's Avatar
yeah there should be two bolts
Old Jan 1, 2007 | 10:48 AM
JP95ZM6's Avatar
That's the Steam Tube. Make sure to use the proper seals. They are 'sealwasher', which is a thin washer with a rubber seal, very similar to what is used at the a/c compressor tube block fitting. Mine had 2 seals per side, from the factory, but the book calls for one. P/N 10108689.
Old Jan 3, 2007 | 06:59 AM
350LT1's Avatar
Thanks for the replies guys.
I did find this P/N list (Thanks to ShBox...I get so much info from this guy), but Advanced auto couldn't find the part. Does this list only work for gmpartsdirect or are these official GM part numbers?
http://shbox.com/1/Parts.htm
Old Jan 4, 2007 | 10:43 AM
350LT1's Avatar
Just wondering if anyone has an answer to my previous question about the part numbers?
Old Jan 4, 2007 | 10:51 AM
93BlackTA's Avatar
Think you can buy the coolant washers (4) from summit racing....think their like $4 each...get 4 of them...
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
