need help guys
Old Mar 6, 2013 | 07:06 PM
TxZ28Guy's Avatar
need help guys
i just got my z28 back from getting the trans rebuilt tongiht. i get in the car and notice my oil pressure gauge is spiked, doesnt move or anything. could something have happened when the trans was being pulled or put back on. or could it be something else. it wasnt like that when i dropped the car off
Old Mar 6, 2013 | 07:37 PM
jloshotz's Avatar
need help guys
Check the sender behind the driver side head, it may have hit the firewall and broken. This happens often when the engine tilts back...ask me how I know
Old Mar 6, 2013 | 08:51 PM
Re: need help guys
We don't know what year car he has (no info posted), so it might not be in that location. But whether it is behind the intake (late years) or by the oil filter (early years), the OP should check it.
Old Mar 6, 2013 | 08:56 PM
TxZ28Guy's Avatar
Re: need help guys
95 z28 lt1
Old Mar 6, 2013 | 09:43 PM
jloshotz's Avatar
need help guys
Same here, check the spot I mentioned. You will need a sender socket and an extension aimed in from near the brake booster to get it out if it is broken, feel for the wire and plug to be sure it's connected first. If the gauge is pinned, it's possible you may have pinched the wire grounding it. If the wire seems to be ok, you may have broken the sender, somehow grounding it internally. When I broke mine (and I was aware to be careful before hand; broke it anyway) the gauge was just zero'ed. This is why I say check the wire first to make sure you didn't catch it between the bell and engine block, or short it otherwise. If you have an inspection mirror it would prove very handy. Let us know what you find!
Old Mar 6, 2013 | 09:52 PM
TxZ28Guy's Avatar
Re: need help guys
Heres what it did
Old Mar 6, 2013 | 10:00 PM
TxZ28Guy's Avatar
Re: need help guys
Found the problem. Somehow the plug got disconnected. Gauge works again
Old Mar 6, 2013 | 10:34 PM
jloshotz's Avatar
need help guys
Awesome, love the easy fix.
Old Mar 6, 2013 | 11:07 PM
TxZ28Guy's Avatar
Re: need help guys
Same here. Thanks for the help.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
