need help guys
Old Apr 20, 2004 | 08:08 PM
speedcrazy's Avatar
need help guys
ok well i pulled the fuel rail off the intake and around the schrader valve it looks to be leaking. im not sure but maybe i made it worse when i was playing around with the fuel pressure gauge.
seems to be leaking right at the bottom where it connects to the fuel line. is this schrader valve welded in there or just screwed in?
maybe that whole line with the schrader valve can be replaced?
im not sure what i can do to fix that up so just looking for input. thanks
Old Apr 20, 2004 | 08:12 PM
bdc95ta's Avatar
the schrader valve is welded on there you have the fuel rail out right if there's a leak in your fuel rail, ( I wonder how u would get one) you would have to by a new one. it's all one peice.
-b
Old Apr 20, 2004 | 09:10 PM
Mike383LT1's Avatar
shrader valve
yes it is formed into the return line unfortunatly you will have to replace it cheack out the for sale forume im sure some one is selling one
Old Apr 20, 2004 | 09:11 PM
transxtreme's Avatar
The schrader valave isnt welded in. Take it out and try some plumbing tape on the threads. If that doesnt work thy tightening the inner part of the valve.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
