Need Help Fixing Oil Leak
Old Sep 11, 2005 | 08:11 PM
casey88's Avatar
I Have A 93 Z And It Has The Common Oil Leak In The Rear Of The Motor Was Is The Best Way To Slow It Down It Is Litlle Let Me Know Thanks Kc
Old Sep 11, 2005 | 08:34 PM
Dave89IROC's Avatar
Re: Need Help Fixing Oil Leak
umm....fix it? if it is the common one from the rear, it is probably the rear of the intake
Old Sep 11, 2005 | 08:47 PM
casey88's Avatar
well i will fix it next summer but i just need it to slow down i am tried of cleaning up oil spots on the floor
Old Sep 11, 2005 | 09:37 PM
CamaroSS30thAnn's Avatar
rear intake seal , or real main , id go with the intake seal,
stick ur hand all the way back behind the manifold and feel around , if u have oil all over ur hands its teh intake
Old Sep 11, 2005 | 10:07 PM
Warlock1313's Avatar
I have never heard of it going away or slowing when the intake gasket seal leaks, get it fixed.
Old Sep 11, 2005 | 10:55 PM
Z95m6's Avatar
Its really not that hard of a fix. It only takes about an hour to have the intake off if that. If you don't want to fix it the right way you could try cleaning the back of the intake and block off real good. Then smearing silicone all over the back and hope it stops.
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
Dr. Weir
Aug 2, 2002 02:36 AM
