Need Help fast!
Old Nov 3, 2004 | 09:29 PM
SkillZ25's Avatar
Need Help fast!
Okay my timing chain broke and I am reinstalling the gears(2 teeth broke) and the chain...My question is when trying to reach TDC on #1 (and 6) How am I supposed to know if its on the intake or exhaust stoke? Thanks
Old Nov 3, 2004 | 09:44 PM
jay_lt4's Avatar
Re: Need Help fast!
when you put the crank gear on the dot should be at 12 o-clock and when you put the cam gear on the dot should be at 6-oclock, you shouldnt need to know about the valve timing unless you are setting your valves???
did you do a leak down test to see if you bent any valves, usually when a person breaks a timing chain the valves hit the pistons and cause all kinds of nasty problems??
more info???
Old Nov 3, 2004 | 10:20 PM
Re: Need Help fast!
This belongs on "LT1 Engine Tech". Moving it there.....
Old Nov 3, 2004 | 10:45 PM
SkillZ25's Avatar
Re: Need Help fast!
...not sure what a leak down test is but Im asking because the crank turned while the cam didnt so they are off now...I know how to get TDC but im not sure how to get the intake stroke of it.
Old Nov 3, 2004 | 10:59 PM
jay_lt4's Avatar
Re: Need Help fast!
doesnt matter, just put the marks they way i posted and you will be ok(as far as setting up the timing chain and gears)
Old Nov 3, 2004 | 11:01 PM
jay_lt4's Avatar
Re: Need Help fast!
but i would be willing to bet that you have bent valves
Old Nov 3, 2004 | 11:02 PM
Re: Need Help fast!
The piston approaches TDC on the compression stroke - both valves are closed. The piston approaches TDC on the exhaust stroke - the exhaust valve (and likely the intake, depending on overlap of the cam) will be open. The piston is at BDC at the end of the intake stroke.
Just get the dots aligned correctly as described above, and the valves will be in the correct position. See Shoebox's cam install instructions for a "Timing chain assembly diagram":
http://shbox.com/ci/cam_install.html
SkillZ25's Avatar
Re: Need Help fast!
Cool thanks for the help man...Guess im just gonna go finish it and find out that I have more problems!!!Sweet!! (I so hope not)
Old Nov 4, 2004 | 06:16 AM
SkillZ25's Avatar
Re: Need Help fast!
Umm guys I cant turn my crank gear anymore. Its at a point where its not turning and I already undid all of the sparkplugs....What do you think? And also what are my chances that I have no bent valves?
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
