need help fast?????
Old Mar 1, 2004 | 09:34 PM
jimmythewall's Avatar
need help fast?????
I just up graded to 3.73 gears this weekend and i was driving home to day and all of the sudden my car started to smoke real bad so i pulled over and my rearend was leaking oil all over the place....what could have happend??? is it the shops fault??? please help......
Old Mar 1, 2004 | 09:37 PM
Riddlerlt1's Avatar
you probably just roasted your pinion seal. Right after i put 3.73's in i had to replace the pinion seal. It happens. But it could also be the pan gasket. THey should fix it for free
OBE1 95Z28's Avatar
Definitely sounds like the shop's fault; fluid got on your exhaust and caused the "smoke show"!
Old Mar 1, 2004 | 09:39 PM
JetLag's Avatar
GRIND!!!!
Old Mar 1, 2004 | 09:50 PM
Could it have any thing to do with my torque arm not being set at -2 degres???
Old Mar 1, 2004 | 09:55 PM
OBE1 95Z28's Avatar
Torque arm setting wouldn't cause a leak; it will cause premature U-joint wear.
Old Mar 1, 2004 | 10:36 PM
The shop could also have over-filled it and it blew out the vent on the top. Have the shop check it out.
Old Mar 1, 2004 | 10:40 PM
should i have my car towed to the shop and if i do shouldnt they pay for it??
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
