need help in dismantle
Old Jul 24, 2003 | 10:42 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
im parting out my car, and some boards members what some pieces, that i do not know how to take out.
1. airbags, both driver and passenger, how do i take out these mechanisms without triggering them? also, how do i saftly ship them?
2. shifter and the shifter mechanism beneith it, under the console.
3. ac compressor
4. headlight and wiper motors
5. steering column with the high beam/ low beam / wiper switch
Old Jul 24, 2003 | 11:00 PM
ChickenScreamer94's Avatar
sad to see you are parting out man. Are you getting another f-body? Well, the driver side airbag is held in by 4 torx bits BEHIND the wheel. They are kinda hard to get to. After those are out just disconnect the little clip. The pass. side i have no idea. The console has to be remove to get to the shifter. Just like three bolts. Then pull the little u clip out of the shifter (on the front bottom of it) with a needle nose plier or screwdriver. it just pops out. Then remove console. I dont know what to do after that but is should be kinda self-explantory i would think. AC comp. has a bolt in the back holding on the lines and then 3 more i think that actually hold it on. I am not sure though, so someone correct me if i am wrong. It is kinda hard to get at. The rest i dont know.
13qtr
Jun 9, 2015 03:30 PM
Chris Anderson
Jan 27, 2015 08:30 AM
bwellard
Advanced Tech
14
Jun 30, 2013 10:27 AM
