Need help with Datamaster file...Car dies after warmed up
Old Jul 9, 2006 | 06:46 AM
Fast96WS6's Avatar
Exclamation Need help with Datamaster file...Car dies after warmed up
Hi all.
Can someone take a look at this Datamaster file for me? I'm having problems with the car stalling out. In this file, I idled the car, reved it twice, then toward the end, it just shuts off.
http://www.1fastws6.com/96LT1Formula.uni
So 2 nights ago, I'm driving my car, and while cruising, the car just dies. No sputtering, or surging, just shuts off like someone turned the key off. I still had power, but no engine.
So I coast into a parking lot, and try to start it. It cranks with no problem, and has full power. But will not catch. My FP guage shows a perfect 42 PSI cranking fuel pressure, so it's not fuel related.
After sitting for about 10 minutes, I try starting the car again, and it starts right up. Idles perfect for about 30 seconds, then shuts right off. It seems to run when the car cools off a bit.
I had the car towed home the next morning and took a look at it. At this point I think it's a coil problem. I went out an purchased a new coil and installed it. Now the car starts right up (it's cold at this point). Idles for a while, and goes into closed loop without a problem, but once it gets hot, it just dies again. No hesitation, no sputtering, litterally just like I turned the key off. So now I have to rule out the coil. Both the coil and the ICM are brand new. I also had the car idling at night, and didnt see any arch near the spark plugs or coil.
The Opti is also fairly new and the car had no symptoms of an Opti related issue. Ive had several Opti's go out on me, and each time, I would have some symptoms, but none this time.
Can someone help me out?
Old Jul 9, 2006 | 09:59 AM
nittanylionlt1's Avatar
Re: Need help with Datamaster file...Car dies after warmed up
FWIW, I bought a brand new ICM from auto zone and it was faulty.
Old Jul 9, 2006 | 01:22 PM
Fast96WS6's Avatar
Well, it was worth the post. Turned out to the the new ICM. It was faulty
David Dempsey
Mar 12, 2016 12:42 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
