need help with Codes
Old Apr 30, 2004 | 03:09 PM
xcycz28x's Avatar
I had my car dynoed and these codes came up
PO 300
P1441
P1870
any help would be appriciated
thanks
charlie
usmc
Old Apr 30, 2004 | 03:20 PM
P0300 Engine misfire detected -normally a random misfire. May or may not return after the code is cleared.
P1441 Evaporative Emissions (EVAP) system flow during non-purge - means the computer sensed that there was vacuum flow to the evaporative emissions canister when there was not supposed to be. May mean the EVAP solenoid is not functioning correctly or that hoses are damaged or misrouted.
P1870 Transmission Component Slipping - tranny slippage detected. Sometimes a random thing. Clear code and see if it returns.
Old Apr 30, 2004 | 03:26 PM
xcycz28x's Avatar
fix??
Thank you for the full discriptiion, I was thinking of getting new plugs and wires, what do you recommend for me to get? Are NGK with Talyor 8.5 wires be good? The guy also said my tranny mount is broken I fixed that before so I got that! how would I fix the EVAP problem? check all my hoses?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
