Need help, clip in oil cooler?
Old May 29, 2004 | 10:16 AM
LilJayV10's Avatar
When I took the oil cooler off the 93 Z28 I'm working on, I unbolted the long "bolt" that the oil filter spins on from the block, then i lifted the actual oil cooler off the engine, there are two bolts that bolt the oil filter adapter to the block. I swear there was a c clip in there that wasn't clipped to anything, it was just sitting there, I have looked and looked, and for the life of me, if it's supposed to go there, I have no idea where. I don't even see what good it would do anywhere in the oil cooler. I want to make sure before I put the engine in the car.
Jason
Old May 29, 2004 | 10:21 AM
96ZRDR's Avatar
Does not the clip keep the long bolt from being removed from the adapter?
dylan1303
May 22, 2015 12:24 PM
KYWes
May 15, 2015 09:10 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
97 RedSS
Jun 10, 2003 07:58 PM
