need help asap
Old Feb 28, 2004 | 03:22 PM
BiGGinZ's Avatar
Question need help asap
I am going to replace my fuel injectors roday but it says I have to have a fuel line release tool set J-37088-A or an equivalent tool to disengage the quick-connect fittings. I was wondering where to get this stuff or if anyone used a different tool that I might have. I need answers asap. Thanks.
Old Feb 28, 2004 | 03:31 PM
ibanez6rg's Avatar
I bought mine at AutoZone. Search LT1 tech regaurding taking the fuel lines off, good info.
Old Feb 28, 2004 | 03:58 PM
RedHottG2's Avatar
I'm not saying you would do this, but just as a tip, be sure to put the fuel injector clips back on with the injectors. They can be a PITA to put back in. I had a friend that thought it would be ok to leave them off and one backed out on him while driving and he almost blew his motor. Just felt I should share this with you.
Old Feb 28, 2004 | 04:21 PM
Alex94TAGT's Avatar
"GM a/c and fuel line disconnect kit" -- about $10 at any auto parts store. Check in the tools section.
Be sure to bleed off the fuel pressure (via the schrader valve on the rear passenger side of the fuel rail, and unscrew the gas cap) before you remove the actual fuel lines. And, get a bucket/towels ready -- some fuel will still pour out after they are disconnected.
Old Feb 28, 2004 | 04:22 PM
BiGGinZ's Avatar
Thanks guys.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
