Cooling-Fan is running all the time
Old Aug 11, 2003 | 09:25 AM
netpat's Avatar
Since a while, the cooling-fan (in my opinion the sound is the fan... I can't see the fan, when I look into to the engine-room) is always running. As soon as the engine is on, 1-2 seconds later, the fan is running.
This isn't normal, right?
Thanks for any idea.
By the way; the ABS-pump is not sounding like a fan, right? Because the ABS-light is on all the time, but the fan-sound-problem exists much longer.
Patrick
Old Aug 11, 2003 | 09:55 AM
63SSRagtop's Avatar
Running all the time is not normal... What year car? primary fan i believe comes on at like 220 and secondary at 230 , or the secondary will kick on after you turn on your ac. Unless your talking about a hot start (after you've been running the car for awhile), its not normal.. It sounds like you may have part of fan circuits grounded out or the relay's to control them are bad.. I'm not sure if/how the abs circuit ties into the cooling fan if it does at all but i certainly would troubleshoot that side first to see what is going on..
Old Aug 11, 2003 | 11:49 AM
Is your SES light on? If so, the fans will be on, too.
Old Aug 11, 2003 | 11:56 AM
97 6SPEED Z's Avatar
Fans running CONSTANTLY is also a sign that your car is in "limp home mode". You may have a PCM problem
Old Aug 12, 2003 | 12:51 PM
netpat's Avatar
Originally posted by 63SSRagtop
Running all the time is not normal... What year car? [...] Unless your talking about a hot start (after you've been running the car for awhile), its not normal [...]
Thank you very much for your ideas. It's a 1994 and the fan is going on by cold start too. 2 seconds after ignation.
Old Aug 12, 2003 | 12:54 PM
netpat's Avatar
Hmm, SES? The only light which is on is the ABS light (another problem... or related?)
Old Aug 12, 2003 | 02:39 PM
Are you sure the SES is working? Does it bulb test when you start the car? Have you checked any fuses, like the AIR pump fuse?
Old Aug 12, 2003 | 02:46 PM
Lyle A's Avatar
Could also be a faulty relay, grounded control wire, faulty fan switch. Just to name a few more things it could be. The ABS light could be because of a burnt third brake light lamp.
Old Aug 12, 2003 | 03:59 PM
InjectedSS's Avatar
are you sure that your a/c just isnt on??
also like shoebox said make sure that your ses light is definately working!
Feffman
Oct 9, 2015 05:42 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Deadbolt24
Dec 18, 2014 08:18 PM
