need help
Old Jun 7, 2006 | 11:33 AM
camaro1fastz28's Avatar
Angry need help
well here the story goes the car sat 3 week wait for a a new torque arm get it back out and drive it well i drive it around made a cupple of hole shot to make sure it was right pinnon angle so i am drive like 60mph rad hose blow off upper ok stupid spring clap pull over change it put water in and go on my way hour later it blow off agine by my garage so i left it there come in the moring put a new hose and clamps. fill the coolent and start it up motor sound like almost free spining but it start and water starts to blow out the the rad cap cause i had it off to bleed the system so what i water start to come out the rad cap i check the oil clean no milk shake dont know where to go next blowen head gasket ?
Old Jun 7, 2006 | 12:52 PM
Re: need help
oo yea it a 1996 camaro z28 6 speed car forgot to tell you all
Old Jun 7, 2006 | 01:12 PM
indirocz28's Avatar
Re: need help
well- you could start by rewriting your thread so we can actually tell your punctuation and what not..- anyways-
My car had been doing that- when you filled it up- did you loosen the bleeder screw to let all the air out of the coolant system?
otherwise air pressure will build up in there- that caused my radiator cap to blow the seal.., and the lower heater hose blew a leak also...
im still new to the LT1 - so you've probably tried that already...
Old Jun 7, 2006 | 01:15 PM
contraststriker's Avatar
Re: need help
Exactly, troubleshooting this post is harder than installing a new opti.
Old Jun 7, 2006 | 01:19 PM
indirocz28's Avatar
Re: need help
lol!- you know- asians often sound that way-.." we wait thareee week fow neww paats, dey do nooo coome innnn fo lonnnng time"..
Old Jun 7, 2006 | 01:33 PM
Re: need help
Old Jun 7, 2006 | 11:25 PM
indirocz28's Avatar
Re: need help
<---- *****y smile
What- i cant say the word - ch,ink?
