Comp guideplates
Old Jun 2, 2006 | 12:47 AM
seawolf06's Avatar
Comp guideplates
I asked about this in another thread, but didn't get any responses.
Why won't the comp cams 4808-8 guideplates work? They look the same and Summit says they're for the LT1, not that they're always right about anything, I just want to know. Thanks.
EDIT: The guys over at comp even said that they were correct. Any ideas???
Old Jun 2, 2006 | 07:00 AM
PoorMan's Avatar
Re: Comp guideplates
I have some pics of both. I ran the comp plates for about 200 miles and the pushrods were grinding. You can see the wear in the pics. They are a tad narrow than the gm ones.
http://community.webshots.com/photo/...44372733bAeqmb
http://community.webshots.com/photo/...44372733UYxlXZ
This one is both plates lined up. The GM plate is in the front.
http://community.webshots.com/photo/...44372733zoPQSe
Old Jun 2, 2006 | 12:11 PM
seawolf06's Avatar
These must be a new design then, because the ones I have also have the curved "face" like the GMPP ones unlike the one in your pics that's straight. Do you know what I'm talking about? I can always open the pushrod guide a little bit with a dremel if that won't ruin the whole purpose of the guideplate. Does anyone know what the clearance should be between the guideplate and the pushrod? Thanks.
Old Jun 2, 2006 | 02:51 PM
roguedriver's Avatar
DO NOT use the Comp guide plates! They will not work on the LT1 castings. I just got done pulling them off in favor of GMPP plates. Luckly for me i didn't put a lot of miles on the new engine, but it was long enough to trash a roller rocker. One plate was so bad that the roller wanted to ride half way off the valve tip, which trashed the rocker. Even a dremel may not help some of them. Spend the $30 and get a set of the GMPP plates. That and the comp's will trash your pushrods also.
Ken R.
Old Jun 2, 2006 | 02:53 PM
seawolf06's Avatar
Did your comp guideplates have the flat section between the pushrod guides or a curved section? What part number were they? Thanks.
Old Jun 3, 2006 | 06:29 PM
PoorMan's Avatar
I do not know of any new design. I bought mine almost 3 years ago so it's possible their is a new design.
Old Jun 3, 2006 | 06:38 PM
seawolf06's Avatar
Can anybody measure the opening for the pushrod on their GMPP guideplates? If possible, could you also measure how far back the curve is on the same side? Thanks.
Old Jun 3, 2006 | 06:51 PM
Josh'95Z28conv's Avatar
Ken R.
You didnt check alignment before running your engine? Wow.
Old Jun 5, 2006 | 07:06 PM
seawolf06's Avatar
I went and just bought the GM ones today. They are a good bit different in design. I'll try to snap a pic or two later.
Old Jun 7, 2006 | 04:26 PM
Nope. Didn't check alignment. Was just one of those overlooked things with all that was going on. Had so many other things going on with the car at the time and didn't know the comp's were an issue or I would have checked for sure. Wasn't used to checking cause I was running self aligners and no guides on the old setup. I chauked it up as an "oops" a learning experience and moved on.
Ken R.
Old Jun 7, 2006 | 04:59 PM
SStrokerAce's Avatar
The reason is that the valve spacing on the heads for the Comp Guideplates and the GMPP Aluminum Bowtie guideplates is different.
Valve Spacing = distance between the intake and exhaust valves.
Run the GMPP ones or Isky Adjustables
Bret
Old Jun 8, 2006 | 01:36 AM
seawolf06's Avatar
Thanks bret.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
