Need help
Old Mar 20, 2005 | 03:58 PM
sean1997ws6's Avatar
Need help
Alright I pulled the valve covers off to adjust a rocker. the car started right up when I started it to adjust the valves and then i turned it off and put everything back together. Then the car would just crank. Wicked Z and I tested the feul pressure and got 43 with a slow fall after the prime, tested the coil and it was good.car cranks but does not fire.any Ideas?
Old Mar 21, 2005 | 05:35 AM
slopokrodrigez's Avatar
Re: Need help
check a couple of plugs for spark. If ok, shoot a little fuel in the intake.
Old Mar 21, 2005 | 05:43 AM
30696bird's Avatar
Re: Need help
Make sure the opti harness is still plugged in. It is right above the pass. side valve cover and you could have pulled it loose or damaged it somehow. Porbly not the problem but it is something to look at.
Old Mar 21, 2005 | 10:14 AM
Re: Need help
Shot some Thrust quick start in there and it just pops
Old Mar 21, 2005 | 10:25 AM
Re: Need help
Time to put a scanner on it. Is the SES light on?
