need help
Old Jan 21, 2004 | 07:15 PM
red_warrior_z28's Avatar
need help
my water pump started leaking real bad, so now i have to change it, right? well i just need help on installing a new one. does anyone know where i can find some directions on how to do it. or can someone give me some clues on how to do it quicker and easier.
Old Jan 21, 2004 | 07:21 PM
Fastbird93's Avatar
Drain the coolant, remove the air intake, disconnect the battery, remove the alternator, power steering pump (I had to so I could access one stinking bolt), remove the water pump. Install in reverse order. It's a pretty easy job.
Old Jan 21, 2004 | 07:48 PM
ive heard you have to bleed the LT1. is this true? and what does it really mean?
Old Jan 22, 2004 | 05:50 AM
Fastbird93's Avatar
There's a couple of bleeding screws for the coolant system located on the upper radiator hoses that go to the water pump. Once you've filled up the system, just start the car, and open those bleeding screws. DO NOT TAKE THEM OUT. Just unscrew them some. When coolant starts to come out, close them, shut the car off, and check your coolant level. Add if necessary. Take car for a test drive for a while. If it runs hot, try bleeding again as there may be a trapped air pocket.
