FP and opti tests
Old Jan 21, 2004 | 03:32 PM
SS Mark's Avatar
FP and opti tests..and 1.7 RR Question
Need to know how to test if the opti and fuel pump are going south.
-Mark
Oh yah!! Does anyone know if the Scorpion 1.7 rr's come with 7/16 rocker studs or do I need to buy those seperate?
Old Jan 21, 2004 | 07:05 PM
SS Mark's Avatar
TTT
Old Jan 22, 2004 | 06:20 AM
Put a fuel pressure gauge on the Schrader connection. 41-47psi at idle, vacuum line disconnected. 35-38psi at idle with vacuum line connected. At WOT, should hold at least 41psi. Shut engine off, fuel pressure should stay near 40psi, and bleed off very gradually.
Opti will set codes for problems in the optical section.... check with a scanner. The high voltage section can only be checked on an ignition scope.
Injuneer
Dec 15, 2014 09:36 AM
naaz90
Jul 27, 2002 08:22 AM
