Need Help.......115MPH?????
Old Jun 24, 2003 | 07:30 PM
Raider Z28's Avatar
Angry Need Help.......115MPH?????
Dilema.....When I hit 115 the car begins to miss out,,WHY????
I have a DE in this car in three days......
Old Jun 24, 2003 | 07:35 PM
Scream And Fly's Avatar
Your car might have the speed governer on it. Some F-body cars did, depending on options ordered.
Why are you going 115 mph anyway? lol.
Greg
Old Jun 24, 2003 | 07:44 PM
Raider Z28's Avatar
Time for a re-program
I did a search and that appears to be the problem.
At TWS I was expecting to hit 135-140 at turn one. Need to get this limit removed tomorrow. Would a Hypertech be able to reprogram it? If so how hard is it to do and where can I get one shipped overnight for delivery on Friday?
Brad
Old Jun 24, 2003 | 07:59 PM
1994CamaroZ28's Avatar
Get a hypertech and you can edit it out yourself, find one on ebay unless you wanna spend 300+
Its easy to work the hypertech a one armed monkey could run it.
Old Jun 24, 2003 | 08:01 PM
revtime's Avatar
Programming is the only way I know of to remove the limiter, you might check and see if Summit can overnite you one.
Old Jun 24, 2003 | 08:05 PM
coletrickle350's Avatar
faster, faster, faster,
common dude you sure you own a camaro? did you put camaro badges on a civic?
I have repeatedly on many an ocasion pegged my speedo for long periods of time, some where around 150 and 160 not sure yet , waiting on a good deal on a gps unit. Btw i don't believe and of the z28's were limited to 115, that sound like my mom's land cruiser. Not sure if the hypertech will remove a speed limiter, i just used cat tuner.
Good luck Mike
Old Jun 24, 2003 | 08:07 PM
Hawk's Avatar
hypertech WILL remove the speed limiter, and yes Z's with the 115mph are governed.
Z's with the QLC option got he Z rated tires and 155mph speedo, apparantly your car was purchased with out this option, which boggles my mind, lol. Who would get a Z with like 100mph rated tires,
Old Jun 24, 2003 | 08:09 PM
revtime's Avatar
If the car came with crappy low speed rated tires then you got speed limited from the factory so you would not kill yourself going 150 mph on a tire rated for 110 or 120. A hypertech will get rid of the speed limiter.
